Individual replacement 4-sided solid TC cutter for the spiral cutter block fitted to the Axminster Workshop AW2260S planer thicknesser. The cutter has four edges, when it eventually dulls, simply turn the cutter through 90°, retighten the screw and you're ready to go again. Each cutter’s edge will last around 10-20 times longer compared to standard high speed steel planer blades.
Web Attribute Set Planer Knives
EAN Barcode 5052511130917
