These replaceable, twin edged blades last many times longer than conventional scraper blads. They are ideal for removing paint, glue, varnish and rust without the need for heat. The blades have convex ground edges to reduce the risk of scratching surfaces and cut on pull or push strokes. These tools find a use with woodworkers, restorers, boat builders and many others.
Blade Length 50 mm
Web Attribute Set Scrapers
EAN Barcode 7311518002848
