Stabila
Stabila 70-2 Levels
SKU: 136584
€20,00
  • Great general-purpose levels
  • Accurate, lightweight and fast
  • Always accurate, work with confidence and speed
  • Large, clear, easy-to-read vials
  • Stabila’s certified accuracy
Stabila 70-2 is a general-purpose level made from strong extruded aluminium alloy. The rectangular box section features an easy, clean, electro-static powder coating and protective end caps. These levels are accurate and lightweight with easy-to-read vials. They are suitable for both light trade and home use. They have three vials, two plumb and one horizontal. A convenient hole is provided to hang the level when not in use. Accuracy is 0.029 or 0.5 mm/m in the normal working position.
Level Length 400 mm (16)
Web Attribute Set Levels
EAN Barcode 4005069141875
