The BORA Automatic Pocket Hole Jig is designed for professionals who demand accuracy, consistency and speed in every joint. Built for repeat performance, this rugged benchtop jig delivers fast, precise pocket holes without the usual setup time. Supplied with a 50-piece sample screw pack, it provides everything needed to start creating strong, reliable joinery straight out of the box.
At the core of the Auto Jig is its intelligent self-calibrating system, which automatically adjusts to match the thickness of the material being joined. This removes the need for manual measuring, setting or fine-tuning, helping you work faster while maintaining consistent results across multiple projects. The streamlined setup is ideal for high-volume work as well as one-off builds where efficiency matters.
The included colour-coded screw system simplifies the process even further, allowing you to quickly match the correct screw size and head type to the depth and thickness of your pocket holes. Each screw features BORA’s Colour-Coat technology, which not only aids identification but also provides anti-corrosion protection, helping to preserve both the fixings and the finished workpiece over time.
BORA Tools is known for creating innovative, problem-solving solutions that improve efficiency for woodworkers, tradespeople and DIY enthusiasts. With a focus on simplicity, durability and performance, BORA products are designed to remove complexity from everyday tasks while delivering reliable, professional results.
The jig features a durable benchtop design built for stability and repeated use. Its self-adjusting mechanism automatically calibrates to suit different material thicknesses, eliminating manual setup. The included screws utilise a colour-coded system with protective coating to ensure easy selection and long-lasting performance.
Supplied as BORA Automatic Pocket Hole Jig along with a 50-piece starter pack of screws, giving you a complete, ready-to-use solution for pocket hole joinery straight out of the box.
Web Attribute Set Pocket Hole Jigs & Accessories
EAN Barcode 9341231064456
