The Kreg Foreman Pocket-Hole Machine is designed to bring fast, consistent and professional pocket-hole joinery into any workshop. Its powerful 230V motor, smooth lever‑controlled action and large working table make it a reliable choice whether you’re batch‑producing components or tackling one‑off builds. With simple tool‑free adjustments, you can set up for materials between 12–38mm thick and achieve accurate pocket-hole depth every time. Clear table markings and spring‑loaded stops help you repeat settings with confidence, keeping your workflow efficient and predictable.
Supplied with a 3/8
For makers who want accuracy, repeatability and speed, the Foreman delivers pocket‑hole joints with minimal effort and maximum reliability.
