The Kreg 76mm and 152mm #2 Square Driver Combo provides a practical solution for driving pocket‑hole screws in a wide range of situations. Both drivers are made with solid one‑piece construction for strength and durability, and feature magnetic tips to help hold screws securely during use. Designed for compatibility with Kreg Quick‑Change chucks, they allow fast, convenient bit changes when moving between tasks.
The 152mm driver offers added reach and flexibility, making it easier to access fixings in deeper recesses or awkward positions, while the shorter 76mm driver is ideal for confined spaces where longer bits can’t be used. Together, they cover most workshop and on‑site requirements, making this set a useful addition to any Kreg joinery setup.
