This case does three things; it protects, organises and stores your UJK pocket hole jig. The construction uses rigid panels covered in hard-wearing nylon. The interior has hook and loop straps to secure the main jig, portable plate, plug cutter, drill bit and long screwdriver bit in place. The lid has a zippered compartment for a clamp and small items. Nothing can get misplaced or lost. When you need to do a job, everything is to hand and you won't waste time hunting around for that one vital piece of equipment that you can’t remember where you last had it. With a place for everything and everything in its place, what can wrong? Internal dimensions of 275 x 160 x 145mm.
Overall L x W x H 290 mm x 165 mm x 160 mm
Web Attribute Set Wood Boring Bits
EAN Barcode 5052511065875
