At the heart of DeWALT’s DCP580, cordless planer is a powerful brushless motor. The advantages include significantly enhanced performance, longer run times and much improved tool life. Supplied without batteries, this planer is compatible with either, DeWALT 4.0Ah Li-Ion or 5.0Ah XR Li-Ion batteries. The DCP580 is capable of removing 2mm in a single pass. The depth of cut adjustment gives you indexed control in 0.1mm increments. The maximum rebate depth is 9mm. The whole machine has good balance; this along with the soft grip handle makes using the DCP580 very controllable and comfortable. The right-handed dust port takes an optional dust bag or connects to a vacuum extractor. The body features on-board storage for spare blades and the necessary Torx key for changing them. It takes standard 82mm double-sided TC blades.
Battery Voltage 18 V
Rating Trade/Professional
Sound Power Level LwA [Uncertainty K] 99 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 88 dB(A) [3.0 dB]
Vibration Cutting Wood [Uncertainty K] <2.5 m/s² [1.5 m/s²]
Web Attribute Set Cordless Planers
EAN Barcode 5035048616253
