Upgraded version of the EHL 65 Festool Planer with a more compact design and other small improvements to make the machine more refined. The cutting block is fitted with a ground solid carbide blade that gives a shear cutting action across the width of the planer block resulting in a very fine finish. Maximum cutting depth of 4mm (accurately controlled in 0.1mm steps), this machine offers fast waste removal with easily handling. Although using only a single blade, the balance of the cutter block is very fine reducing vibration to a minimum. Changing the blade is simple and no further settings are required. The overall size and layout of the planer make it very easy to use single-handed. Supplied complete with parallel side fence, plug-it cable and Supplied in Systainer SYS3 M 187 case.
Dust Extraction 27 mm Outlet
Rating Trade/Professional
Sound Power Level LwA [Uncertainty K] 88 dB(A) [3.0 dB]
Corded or Cordless Corded
Sound Pressure Level LpA [Uncertainty K] 77 dB(A) [3.0 dB]
Motor Power 720 W
Manufacturer Part Number 574560
Voltage 230 V
Web Attribute Set Power Planers
EAN Barcode 4014549193730
