Amana Tool
Amana Spiral Down Cut Plastic Cutting Router Cutters With Spektra
SKU: 111607
£7.73 £30.28 Save £22.55
£6.44 Excl. VAT
  • High quality carbide
  • Ideal for industrial applications
  • Suitable for cutting acrylics and plastics
  • Mirror finish cutting edge
  • Designed to eject chips up
These spiral 'O' flute router bits are ideal for industrial applications and are manufactured to produce optimum results on every cut, especially when cutting acrylic materials and plastics. Made from high quality carbide, they feature a polished mirror finish cutting edge. This means a cleaner cut, reduced risk of chip re-welding, extended tool life and dissipates heat well to prevent melting. Left hand helix left hand cut.
These router bits can be used to cut the following materials:
Plastic/Acrylic
Acetal and Nylon
Acrylic Stone
Acrylonitrile Butadiene Styrene (ABS)
Aluminum Composite Material (ACM)
Alupanel®
Corian
Coroplast®
Corrugated Plastics such as Correx Boards and Polypropylene
Crosslinked Polyethylene (XPE, PEX, XLPE)
Delrin
Dibond®
Extruded Acrylic
Foam Board
Fomex®
Gatorfoam®
Hard Plastic
High Density Polyethylene (HDPE)
High Density Urethane (HDU Board)
High Impact Polystyrene (HIPS)
High Impact Polystyrene (HIPS) for digital printing
High Pressure Laminates (HPL)
Hydroxy-Terminated Polyether (HTPE)
King ColorCore® The Multi-Color Engravable Polymer Sheet.
Laminate
Low Density Polyethylene (LDPE)
LubX®
Lucite®
Mechanical/Engineered Plastics
Perspex® Cast Acrylic Sheet
Plexiglas®
Poly (methyl methacrylate) (PMMA)
Polycarbonate (Lexan™)†
Polyethylene Terephthalate Glycol-Modified (PETG / PET-G)
Polyoxymethylene (POM), also known as Acetal, Polyacetal and Polyformaldehyde.
Polystyrene (PS)
PVC
Sign Foam
Sintra PVC
Solid Surface
StarBoard® (King StarBoard 'R') High Density Polyethylene Sheet (HDPE)
Teflon®
Thermoplastic Polyolefin (TPO)
Trespa® Meteon®
Ultra High Molecular Weight Polyethylene (UHMWPE)
Urethane
Vinyl Flooring
Wood
With a brilliant distinctively-tinted coloring, the Spektra™ nACo nanocomposite coating provides additional improvements in four critical aspects of router tooling.
nACo coating is a micro-thin ceramic coating which enables the tool's cutting edge to retain crucial sharpness and lubricity. This provides longevity and produces cutting results of the highest quality.
Coating prevents high heat and oxidation which is detrimental to cutting tool performance.
Multi-colored hues, while attractive, will dissipate upon use and yet coating will remain fully effective.
nACo offers approximately 4,500 Vickers for impressive solid hardness on cutting areas of the tool, for an increase up to 2.5 times compared to uncoated bits.
Note: Blue based color dissipates immediately upon use. nACo® nanocomposite coating will not wear off.
Suitable for use with CNC Routers and shouldn't be used with a handheld router.
Shank Diameter 1/8" (3.2 mm )
X = Depth of Cut 12.7 mm (1/2")
D = Overall Diameter 3.2 mm (1/8")
Web Attribute Set Spiral Router Cutters D: 3.2 X: 12.7
