Arbortech
Arbortech Diamond Disc for Mini Power Carver
SKU: 109682
£16.80
£14.00 Excl. VAT
  • For use with Arbortech Mini Carvers
  • For small repairs and restoration work
  • Suitable to use with marble, concrete, resin and metals
Designed for the Arbortech Mini Carver, this disc adds another dimension to the tool. The Mini Carver is an incredibly versatile trade tool. The addition of a diamond disc allows you to use it for grout removal and repair and other custom jobs in restoration metalwork and other masonry applications. The Mini Carvers extension arm makes it ideal for reaching tight spots that larger grinders simply cannot compete with.
Choose either 1.2mm or 1.5mm thickness, for small repair work, cutting marble, concrete, grout joints, cutting out marble, very hard epoxy resin, fibreglass and cement joints. These 54mm diameter blades are suitable for many smaller repair, renovation and restoration tasks.
Kerf 1.2 mm
Web Attribute Set Angle Grinder Discs
EAN Barcode 9313478902877
