Arbortech
Arbortech Single Flat Chisel 20mm
SKU: 113426
£32.45
£27.04 Excl. VAT
  • Replacement 20mm Chisel for the Arbortech Power Chisel™
  • Manufactured from high strength carbon steel
  • Heat-treated for optimum hardness
Arbortech Single Flat 20mm Replacement Chisel
Engineered for use with the Arbortech Power Chisel™, this flat 20mm chisel offers clean, controlled cuts. Made from high-strength carbon steel and heat-treated for long-lasting edge retention and performance.
Web Attribute Set Power Carving Accessories
EAN Barcode 5052511142644
