The TURBO Shaft is a power carving attachment for use fitted to the Arbortech Power Carving Unit or most 100mm (4") or 115mm (4.1/2") angle grinder. Designed to complement the Arbortech TURBO range or as a stand-alone tool. The TURBO Shaft provides the means to carry out detailed freehand carving. It combines efficiency with exceptional control. The TURBO Shaft has replaceable carbide teeth offering excellent performance and durability even in the hardest timbers. The adjustable depth gauge makes it easy to quickly set your depth of cut. The unique TURBO Shaft is a versatile addition to any woodworker’s arsenal. It is particularly effective for deep and narrow profiles, detailed sculpting, template work and more.
Arbortech
Arbortech TURBO Shaft
| Web Attribute Set | Power Carving Accessories |
| EAN Barcode | 9313478321012 |
