Axcaliber
Axcaliber Bearing Guided Cove Cutters
SKU: 666156
£26.98
£22.48 Excl. VAT
  • Bearing ensures consistent profile
  • Use with matching rounding over to produce a rule joint
  • Make trim moulding from specific timber
  • Precision made on multi axis CNC machines
  • High shear-cut angle for cleaner finish
  • Thick PTFE coating helps cutter to remain free of resin
  • Available in 1/4(6.35mm) or 1/2(12.7mm) shanks
  • 12.7mm radius
A simple cove moulding can make an attractive feature when used for enhancing furniture, trim around cupboards or laminate flooring. This 1/2 radius bearing guided cutter is available in either 1/4 or 1/2 shank sizes.
Shank Diameter 1/4" (6.35 mm)
X = Depth of Cut 16 mm (5/8")
D = Overall Diameter 35 mm
R = Radius 12.7 mm (1/2")
Web Attribute Set Radius, Cove & Cavetto Router Cutters D: 35 R: 12.7 X: 16
EAN Barcode 5052511030088
