Axcaliber
Axcaliber Bevel Trim Cutter
SKU: 666093
£15.78
£13.15 Excl. VAT
  • For flush trimming laminates
  • Bearing guided for consistent result
  • Ideal for use in palm routers or laminate trimmers
  • Precision made on multi axis CNC machines
  • High shear-cut angle for cleaner finish
  • PTFE coating helps cutter to remain free of resin
For flush trimming laminates where a bevel is required this bearing guided cutter will give consistently good performance. A good choice for use in palm routers or laminate trimmers.
Shank Diameter 1/4" (6.35 mm)
X = Depth of Cut 9.5 mm (3/8")
D = Overall Diameter 23 mm
K = Cutter Angle 30
Web Attribute Set Trimming Router Cutters D: 23 X: 9.5
EAN Barcode 5052511029648
