The Axcaliber range of Contract TCT (Tungsten Carbide Tipped) circular saw blades offers an unmatched blend of choice, cutting performance and price. Manufactured in one of the most advanced facilities in the world, they are produced to the highest standards using the finest materials available. With the range covering everything from handheld power tools right up to large panel saws used in production workshops, you will be certain to find a blade to suit every requirement. These 160mm blades are for handheld circular saws and have a thin kerf for lower power requirements. 20mm bore.
Axcaliber
Axcaliber Contract 160mm TCT Saw Blades
| Blade Diameter | 160 mm |
| Maximum RPM | 10,000 rpm |
| Kerf | 2.2 mm |
| Teeth | 28 |
| Tooth Format | ATB |
| Plate Thickness | 1.5 mm |
| Hook Angle | 18 |
| Bore Size | 20 mm |
| Blade Application | General Purpose (28 teeth) |
| Web Attribute Set | Circular Saw Blades |
| EAN Barcode | 5052511062881 |
