Axcaliber
Axcaliber Contract TCT Saw Blade Neg Rake - 215mm x 2.2mm x 30mm 56T
SKU: 800054
£20.98
£17.48 Excl. VAT
  • Generously sized tips brazed onto tensioned quality steel plates
  • Negative rake (56 teeth), gives a smooth, safe cut
  • Perfect for mitre saws
  • 2.2mm kerf, 1.6mm plate
  • 30mm bore
The Axcaliber range of Contract TCT (Tungsten Carbide Tipped) circular saw blades offers an unmatched blend of choice, cutting performance and price.
Manufactured in one of the most advanced facilities in the world, they are produced to the highest standards using the finest materials available. With the range covering everything from hand held power tools right up to large panel saws used in production workshops, you will be certain to find
a blade to suit every requirement. Bore size 30mm. These negative rake blades are a perfect choice for a mitre saw, the rake of the tooth will help prevent the blade from grabbing, creating a smoother, safer cut. The finish is 1st class on all natural timbers or man made boards.
Blade Diameter 215 mm
Maximum RPM 8,000 rpm
Kerf 2.2 mm
Teeth 56
Tooth Format ATB
Plate Thickness 1.6 mm
Hook Angle 5 Negative Rake
Bore Size 30 mm
Blade Application Negative Rake (56 teeth)
Web Attribute Set Circular Saw Blades
EAN Barcode 5052511000241
