Axcaliber
Axcaliber Convex Multi-Bead Cutter
SKU: 666183
£32.28
£26.90 Excl. VAT
  • Create an attractive triple bead edging
  • Bearing guide for use on curved work
  • Decorative edges on table tops and shelving
  • Precision made on multi axis CNC machines
  • High shear-cut angle for cleaner finish
  • PTFE coating helps cutter to remain free of resin
  • 1/4 shank
  • 3.2mm radius
Used with either the fence or without (self guided) this cutter produces a very attractive triple beaded edge in one simple pass, stopping the moulding short creates a good looking edge for shelving.
Shank Diameter 1/4" (6.35 mm)
X = Depth of Cut 25.4 mm (1")
D = Overall Diameter 22.2 mm (7/8")
R = Radius 3.2 mm (1/8")
Web Attribute Set Beading & Reeding Router Cutters D: 22.2 R: 3.2 X: 25.4
EAN Barcode 5052511030316
