Axcaliber
Axcaliber Thumb Mould Cutter - 1/2" Shank
SKU: 666199
£49.98
£41.65 Excl. VAT
  • Traditional elliptical profile
  • Used to give a lighter appearance to tabletops
  • Often found on skirting, architrave and the tops of handrails
  • Precision made on multi axis CNC machines
  • High shear-cut angle for cleaner finish
  • PTFE coating helps minimise resin build-up
A traditional elliptical profile commonly found on tabletop edges, sometimes with a quirk on the top. The thumb mould gives a lighter appearance to a heavy table or bench top, where a more angular profile would soon wear. The thumb mould appears in skirting, architrave and the tops of handrails.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
Shank Diameter 1/2" (12.7 mm)
X = Depth of Cut 19 mm
D = Overall Diameter 67 mm
Bearing Diameter 12.7 mm Web Attribute Set: Thumb & Panel Moulding Router Cutters D: 67 X: 19
EAN Barcode 5052511030477
