Axcaliber
Axcaliber Twin Flute Small Diameter Straight Cutters - 1/2"(12.7mm)
SKU: 107823
£9.58 £12.58 Save £3.00
£7.98 Excl. VAT
  • 1/2 shank helps eliminate vibration
  • Eliminates chatter under load
  • High shear-cut angle for cleaner finish
  • PTFE coating helps minimise resin build-up
A high quality range of twin flute 1/2(12.7mm) shank cutters available in metric and imperial sizes the metric having a bottom cut insert for improved plunge cutting. The larger shank of these cutters helps eliminate vibration and chatter under load and if your router will accept a 1/2(12.7mm) collet these cutters are are a good choice for many different applications.
X = Depth of Cut 25 mm
D = Overall Diameter 12.5 mm
Web Attribute Set Straight Router Cutters D: 12.5 X: 25
EAN Barcode 5052511125890
