Axcaliber
Axcaliber Vee Groove Cutters
SKU: 666269
£18.68
£15.57 Excl. VAT
  • A most useful router cutter
  • Use for a myriad of tasks
  • Engrave letters when sign making
  • Produce a chamfer on an edge
  • High shear-cut angle for cleaner finish
  • PTFE coating helps minimise resin build-up
Vee groove cutters are useful where large panels need to give the appearance of tongue and groove construction or freehand carving and lettering for signs. 1/4 or 1/2 shank versions available.
Shank Diameter 1/4" (6.35 mm)
X = Depth of Cut 16 mm (5/8")
D = Overall Diameter 19 mm
K = Cutter Angle 45°
Web Attribute Set Chamfer, Engraving & V-Groove Router Cutters D: 19 X: 16
EAN Barcode 5052511031085
