The Axminster 15 Piece 1/4 (6.35mm) Router Cutter Set is the perfect entry level set. It comprises 15 quality router cutters, for use in a 1/4 router. All 15 can be used in hand held routers and routers fixed in tables. They are tungsten carbide tipped, making them extremely durable. Suitable for use with hardwoods and man-made boards such as MDF and plywood.
Contents:
1 x bearing guided roman ogee cutter 4mm (5/32) radius x 27mm (1.1/16) diameter
1 x 25° bearing guided Chamfer cutter x 25.4mm (1) diameter
1 x 3mm (1/8) radius bearing guided rounding over cutter x 19mm (3/4) diameter
1 x bearing guided cove cutter 10mm (25/64) radius x 28.5 (1./18) diameter
1 x 15° dovetail cutter x 12.7mm (1/2) diameter
1 x 60° V-groove cutter x 16mm (5/8) diameter
1 x 4mm (5/32) bearing guided slotting cutter x 32mm(1.1/4) diameter
1 x straight cutter 8mm (5/16) x 20mm (25/32) depth of cut
1 x 12.7mm (1/2) diameter flush cutter with bottom bearing x 25.4mm (1)
1 x 45° bearing guided chamfer cutter x 35mm (1.3/8) diameter
1 x straight cutter 10mm (25/64) x 30mm (1.3/16) depth of cut
1 x bearing guided rebating cutter x 32mm (1.1/4) diameter
1 x straight cutter 16mm (5/8) x 30mm (1.3/16) depth of cut
1 x 6.35mm (1/4) radius bearing guided rounding over cutter x 25.4mm (1) diameter
1 x 16mm (5/8) diameter flush cutter with top bearing x 25.4mm (1)
