Axminster 8 Piece Drill Stop Collar Guide Set
SKU: 507150
£9.98
£8.32 Excl. VAT
  • Aluminium, anodised colour coded finish, 8 sizes, 3mm to 10mm
  • Precision drilling to depth using a pillar or handheld drill
  • Fits any drill bit, including spade bits
  • Protective, self adhesive washer
  • Allen key included
  • Rigid plastic case with foam liner
This set of colour coded aluminium drill stop collars is a very useful addition to the workshop or toolbox. The set is contained in a foam lined, rigid plastic container so it becomes easy to see at a glance when one is missing. They will fit any drill shank within the range and are supplied in a set of eight, starting at 3mm and progressing in one millimetre incremental steps up to 10mm. Also supplied for each collar is a self adhesive rubber washer, which will ensure that there is no damage inflicted on a delicate surface.
Web Attribute Set Drilling Guides
EAN Barcode 5052511063543
