Axminster Drum Sander Replacement Sleeves
SKU: 108514
£9.98
£8.32 Excl. VAT
  • Pack of 4 replacement drum sanding sleeves
  • 1 each 25.4mm (1) 50mm (2), 63mm (2.1/2) and 75mm (3)
  • Available in 80 or 120 grit
Aluminum Oxide Drum Sanding Sleeves, 75mm long. Each pack contains four sleeves, 1 each 25.4mm (1) 50mm (2), 63mm (2.1/2) and 75mm (3). Suitable for the Axminster Drum Sanding Set. Cloth-backed for longevity and simple changes.
Abrasive Backing Cloth
Pack Quantity 4
Abrasive Grit 80
Web Attribute Set Drum Sander Machine Loadings
EAN Barcode 5052511127481
