Axminster Happy Fingers Feather Board
SKU: 114236
£16.98
£14.15 Excl. VAT
  • Supplied as a pair for versatile use
  • Stack together for extra holding power
  • Improves cut accuracy and consistency
  • Helps reduce kickback for safer machining
  • Keeps hands safely away from blades and cutters
  • Includes comprehensive fixing kit for quick setup
The Axminster Happy Fingers Feather Board is a simple yet highly effective workshop safety accessory that improves both control and cutting accuracy. Designed to apply consistent pressure against the fence or table, it helps keep your workpiece securely in position, reducing movement and minimising the risk of kickback for smoother, more precise results.
Supplied as a pair, the feather boards can be used individually for everyday machining or stacked together to provide additional holding power when working with taller or thicker material. Their multi-directional feathered design maintains even pressure throughout the cut, allowing stock to feed smoothly while keeping it firmly under control.
By holding the workpiece securely, the Happy Fingers Feather Boards help keep your hands further away from blades and cutters, giving you greater confidence and a safer working environment. Suitable for use with a wide range of table saws, router tables and other woodworking machines, they fit standard mitre slots and fence systems and include a comprehensive fixing kit for quick, secure installation.
Whether you're making repeat cuts, routing profiles or machining awkward stock, the Axminster Happy Fingers Feather Board set is an essential addition to any workshop, helping you achieve safer operation, greater accuracy and consistently cleaner results.
Overall L x W x H 160 x 16 x 205 mm
Web Attribute Set Router Table Accessories
EAN Barcode 5052511147281
