Axminster HC110 Chuck Style Handpiece
SKU: 112168
£65.38
£54.48 Excl. VAT
  • Chuck style mechanism
  • Compatible with 5/64 to 5/32 tools
  • Easy bit changes between applications
  • Precision engineered for concentricity
  • For AP250FSG Flexi Shaft Grinder
The Axminster Professional HC110 Chuck Style Handpiece is a precision-engineered accessory for the AP250FSG Flexi Shaft Grinder. Featuring excellent concentricity and a grooved, non-slip grip, it's stable and comfortable to use - even during extended sessions. This handpiece is compatible with tools and drill bits ranging from 5/64 to 5/32 (approximately 2 - 4 mm), making it ideal for a wide range of fine-detail applications, and the chuck-style mechanism allows for quick and secure bit changes.
When paired with the AP250FSG, the HC110 enhances control and versatility, allowing users to perform engraving, drilling, grinding, and polishing tasks with confidence. Whether you're a professional craftsperson or a dedicated hobbyist, the HC110 is a reliable and adaptable choice for precision work.
Web Attribute Set General Mini Tool Accessories
EAN Barcode 5052511138869
