Axminster Hi-Flex Air Line with PCL Fittings
SKU: 111694
£32.58
£27.15 Excl. VAT
  • Professional quality, 10mm bore hose
  • Male and female quick release PCL fitting securely to the ends
  • Max working pressure of 15 Bar / 217 PSI
The Axminster Professional Hi-Flex Air Line hose is a multi-purpose PVC hose, ideal for general workshop and air tool use. This 10mm bore hose has one male and one female quick release PCL fitting. Available in 2 lengths.
It is made from flexible polyester and reinforced PVC. It offers superior flexibility, excellent kink and abrasion resistance, as well as great resistance to the effects of weather and chemicals to ensure for long lasting use. Minimum frictional loss is achieved by the smooth bore.
Hose Length 5.0 m
Web Attribute Set Air Hoses
EAN Barcode 5052511135899
