Axminster Quick Release Airline Fitting 10mm Hose Tail To Euro Male Bayonet
SKU: 105373
£4.28
£3.57 Excl. VAT
  • 10mm male hose tail with Euro male bayonet
  • Use to make up custom hoses
  • Converts compressors or air tools to quick release
  • Positive spring-loaded lock, easy push-fit
  • Compatible with most common compressors and fittings
  • 8mm nominal bore for improved airflow
Use these top quality Euro airline fittings for making up custom hoses or to convert your compressor or other air tools to a quick release system. The 8mm nominal bore offers a much improved airflow when compared to some other common systems. The female connectors feature a push-fit, spring-loaded positive lock action. All fittings are hardened for a long, trouble free working life. They are suitable for most workshop compressed air applications. Female connectors have either male or female 1/4" BSPT threads. Male connectors are available with male or female 1/4" BSPT threads or a hose tail.
Web Attribute Set Airline Fittings
EAN Barcode 5052511108848
