Axminster VC Abrasive Disc - 125mm
SKU: 113599
£0.98
£0.82 Excl. VAT
  • Hook and loop abrasive sanding discs
  • Available in a range of grits
  • Compatible with the Perform PD15BDS Belt & Disc Sander
Axminster VC Abrasive Discs with a hook and loop sanding disc, available in a range of grits. Aluminium oxide for general purpose sanding applications.
Compatible with the Perform PD15BDS Belt and Disc Sander. 125mm diameter.
Abrasive Backing Hook and loop
Abrasive Grit 80
Abrasive Disc Diameter 125 mm
EAN Barcode 5052511143832
