Bahco
Bahco 59/S36BCR Ratcheting Coloured Bit Set, 36 Piece
SKU: 112678
£39.98
£33.32 Excl. VAT
The Bahco 59/S36BCR Ratcheting Coloured Bit Set contains a wide selection of bits suitable for universal use. Each bit is made from high-performance alloy steel. TORX bits are colour coded to easily identify the size of the tip. Supplied in a durable carry case. Contains:5 x 25mm Phillips Bits: PH0, PH1, PH2, PH3 and PH2G.4 x 25mm Pozidriv Bits: PZ0, PZ1, PZ2 and PZ3.7 x 25mm TORX Bits: TX10, TX15, TX20, TX25, TX27, TX30 and TX40.3 x 25mm Slotted Bits: 4.5, 5.5 and 6.5mm. 8 x 25mm Hexagon Bits: 1.5, 2, 2.5, 3, 4, 5, 6 and 8mm.6 x Magnetic Nut Drivers: 6, 7, 8, 10, 11 and 13mm.1 x 1/4 Socket Adaptor.1 x KM653 Magnetic Universal Bit Holder.1 x Ratcheting Screwdriver Handle.
Web Attribute Set Screwdriver Bits
EAN Barcode 7314150413232
