Clean accurate and tear free on both sides of the hardwood and laminate material. Two rows of teeth arranged at different angles, a razor sharp scalpel tooth will cut the wood fibres on the reverse whilst a precision ground pointed tooth separates the wood fibres on the top surface and give super clean cuts. BIM longlife blades suitable for hard wood and high quality laminate boards.
Jigsaw Blade Length 91 mm
Max Cutting Depth 20 mm
Model T308BF (Pkt 5) Quantity: 5 Web Attribute Set: Jigsaw Blades Jigsaw Cutting Depth [Cat]: 5-50 mm
EAN Barcode 3165140470322
