Festool
Festool 150mm Interface Pad PP-STF-D150 (Pkt 2)
SKU: 104496
£9.48
£7.90 Excl. VAT
  • Interface pad fits between the sanding pad and abrasive disc
  • Recommended for use with net type abrasives
  • Minimises wear and tear on sander’s base
  • Extends the life of the sander’s base
  • Hook and loop fixing, simple to use
  • Supplied in a pack of 2
Use of this interface pad has several benefits. Particularly when using net style abrasives, it provides a much improved connection between your sander and the abrasive disc. The protection pad also minimises wear and tear on the hook and loop facing on your sander’s base, greatly extending the working life of the base.
When the interface pad eventually wears simply peel off and replace. The pad comes in a pack of 2, so you will immediately have a spare to hand. Diameter 150mm to fit the following Festool sanders: RO 150, ES 150, ETS 150, ETS EC 150, LEX 150, WTS 150, HSK-D 150.
Manufacturer Part Number 203343
EAN Barcode 4014549306178
