Festool
Festool 90 Degree Guide Rail Edge Square FS-WA/90
SKU: 106849
£149.68
£124.73 Excl. VAT
  • Make precise 90 cuts every time
  • CNC machined anodised aluminium for accuracy and durability
  • Quick lever clamp, attaches to guide rail in seconds
  • Highly accurate cutting of sheet material
  • Long contact surface for easy aligning with all edges
  • Completely self-aligning, no adjustment necessary
Guaranteed, precise 90 alignment every time you use the Festool FS-WA/90 attached to a Festool guide rail. CNC machined from a single piece of aluminium and fitted with a quick action locking clamp makes it impossible to cut at anything other than exactly 90. Used in combination with a circular saw, the FS-WA/90 and guide rail become a highly accurate mobile panel saw. Slide the square into the T-slot of your guide rail and close the latch; setup is as simple as that.
The FS-WA/90 features a long contact edge for positive alignment on a front or rear reference edge depending on the situation.
Grooves on the underside enable you to attach guide rail clamps for extra security.
Manufacturer Part Number 205229
EAN Barcode 4014549363683
