Festool
Festool Abrasive Granat PROfile 125mm Discs
SKU: 114400
£19.98
£17.48 Excl. VAT
  • Foam‑backed 125mm abrasive for precise contour sanding
  • Prevents breakthrough and uneven sanding marks
  • Designed for detailed finishing work
  • Long‑lasting GRANAT abrasive quality
  • Compatible with Festool 125 mm random orbital sanders.
Festool GRANAT PROfile 125 mm abrasive discs are engineered for machine‑operated profile sanding where precision and surface protection are essential. The soft 13 mm foam backing follows contours and edges closely, allowing uniform material removal without cutting grooves into the workpiece.
These abrasives are ideal for detailed finishing on decorative components, trims and shaped surfaces, delivering reliable results across wood, paint, filler and contemporary coatings. Perfectly matched to Festool sanding machines, supporting efficient dust extraction and clean sanding within the Festool system.
Supplied in Medium, Fine, Super Fine and Mixed options for flexible sanding progression.
Compatible with Festool 150 mm random orbital sanders, and also suitable for use with other 150 mm random orbital sanders.
Abrasive Material Granat
Abrasive Backing Foam
Manufacturer Part Number 578796
Abrasive Grit Medium
EAN Barcode 4014549465424
