Festool
Festool Abrasive Systainer & 125mm Granat Discs
SKU: 112138
£79.98
£66.65 Excl. VAT
  • Systainer includes a range of GRANAT abrasive
  • GRANAT abrasives achieve a seamless sanding experience
  • Tough aluminium oxide and hard ceramic grit, long lasting
  • Resists clogging and smearing, high quality surface finish
  • Enables easy closing, opening, and connecting with other Systainers
  • Can be connected to all previous Systainer generations, various machines and accessories
  • Safeguards your abrasives from dust, spraying water, and bending
The ultimate solution for keeping your abrasives neatly arranged and easily accessible – the Festool abrasives Systainer. This innovative storage system is designed to complement your sander perfectly, offering a wide range of grit sizes to meet all your sanding needs.
The abrasives Systainer is equipped with 100x GRANAT sanding discs, ranging from P60 to P220, ensuring you always have the right grit size at your fingertips. Within the set you get 20 sheets for each of the following grit types: P60, P80, P120, P180, and P220. Granat with its tough aluminium oxide and hard ceramic grit is long lasting and can be used on many different materials. Each compartment is organised by grit size, allowing you to find the required disc in seconds. The easy filling system ensures you always have an ample supply of the necessary grit size.
The GRANAT sanding discs are specially suited for VOC varnishes and hard substrates. Thanks to their special coating, clogging is avoided, ensuring a long service life. Additionally, other substrates can be processed with the GRANAT abrasive without any issues. The discs are also FSC™-certified, making them an environmentally friendly choice.
In terms of protection, the Systainer ensures your abrasives are safeguarded against external influences such as dust, spraying water, and bending. It also facilitates professional transportation of your abrasives to the construction site. The Systainers are compatible with each other and can be connected to all previous Systainer generations, as well as many machines and accessories. Fits; RO 125, ES 125, ETS 125, ETSC 125, ES-ETS 125, ES-ETSC 125, ETS EC 125, LEX 125.
Supplied in a SYS3 M112 Systainer with 100 x 125mm discs in total, 20 each; P60, P80, P120, P180, and P220.
Manufacturer Part Number 578193
Pack Quantity 100
EAN Barcode 4014549440612
