Festool
Festool Abrasive Systainer & 150mm Granat Discs in Systainer
SKU: 113167
£99.98
£83.32 Excl. VAT
  • Comprehensive set of Granat abrasive discs for various sanding tasks
  • High-quality abrasives for maximum performance and durability
  • Includes a range of grits from P60 to P220 for different sanding needs
  • Systainer SYS3 M 237 for organised storage and easy access
  • Enhances efficiency and convenience in your sanding projects
The Festool Abrasive Systainer & 150mm Granat Discs in Systainer is the perfect solution for all your sanding needs. This comprehensive set includes a variety of Granat abrasive discs, ensuring you have the right grit for every task. The high-quality Granat abrasives are designed for maximum performance and durability, providing excellent results on a wide range of surfaces. The included Systainer SYS3 M 237 keeps everything organised and easily accessible, making your sanding projects more efficient and enjoyable.
This pack contains:
20x Granat STF D150/48 P60 GR abrasive: Ideal for heavy material removal.
20x Granat STF D150/48 P80 GR abrasive: Perfect for intermediate sanding.
20x Granat STF D150/48 P120 GR abrasive: Great for fine sanding.
20x Granat STF D150/48 P150 GR abrasive: Suitable for very fine sanding.
20x Granat STF D150/48 P180 GR abrasive: Excellent for finishing touches.
20x Granat STF D150/48 P220 GR abrasive: Ideal for ultra-fine sanding.
Systainer SYS3 M 237: Provides organised storage and easy transport.
Abrasive Type Granat
Manufacturer Part Number 578192
EAN Barcode 4014549440599
