Festool
Festool Antistatic Hose with Bypass D27/32 - 5m
SKU: 108548
£213.98
£178.32 Excl. VAT
  • Smooth outer casing makes all the difference
  • Anti-static, light and extremely flexible hose
  • Bayonet connection with adjustable airflow
The robust, smooth outer casing makes all the difference compared to standard corrugated hoses. This 5m hose won’t catch on every corner and minimises the possibility of damage to delicate work surfaces. The hose itself is anti-static, light and extremely flexible. The smooth internal bore offers smoother airflow. The hose has an RFID chip for automatic suction hose detection.
This bayonet connection to your Festool power tool is quick and secure and it can be detached equally quickly. The bayonet connection features an infinitely adjustable bypass, which allows you to set the airflow rate to suit the power tool in use or particular task.
This feature enables you to work efficiently with different tools, cleanly and systematically. Its compact design won’t interfere with the handling of the power tool and the rotating adapter prevents the hose from twisting.
The bayonet connection conveniently fits into the opposite end for storage and transport, keeping any remaining dust in the hose. This feature also allows you to join two or more hoses for extended reach.
Suitable for Festool extractors CT 26/36/48 and for the CT MINI, and CT MIDI from Jan 2019.
Manufacturer Part Number 577159
Web Attribute Set Filter Bags & Accessories
EAN Barcode 4014549401262
