Extend your runtime and keep your workflow moving with the Festool Battery & DUO Charger Set 18V (2 x 5.0Ah HP), a practical power solution designed for demanding workshop and site use. Supplied in a robust Systainer³, this set combines two high-performance battery packs with a dual charger, ensuring you always have power ready when you need it. Ideal as an addition to Festool Basic kits or as a reliable backup system, it supports a wide range of 18V applications with efficiency and convenience built in.
At the core of the set are two 5.0Ah Li-HighPower battery packs, offering strong performance across a broad range of tasks while remaining compact and lightweight. These batteries deliver increased power output with compatible tools, making them well suited to both heavy-duty and general-purpose work. The included TCL 6 DUO rapid charger allows you to charge two batteries at the same time, eliminating downtime and removing the need for multiple chargers or sockets, particularly useful on site or in mobile work environments. Bluetooth® functionality enables automatic activation of a paired Festool dust extractor when the tool is switched on, while integration with the Festool app provides access to detailed battery information such as charge status, temperature and usage data.
Everything is neatly stored in the Systainer³ SYS3 M 187, with space for additional batteries if required.
Festool is renowned for its system-led approach to power tools, delivering high-performance solutions designed to work seamlessly together. With a focus on durability, efficiency and user convenience, Festool products are trusted by professionals who demand reliability and precision in every task.
Part of the Festool 18V family
Supplied with 2 x 5.0Ah HighPower battery packs (BP 18 Li 5.0 HP-ASI), TCL 6 DUO rapid charger (230V) and Systainer³ SYS3 M 187.
