A set of 6 precise cutting drill bits for wood, solid and manmade as well as MDF and acrylic.
With a brad point design and sharp centre point and outer cutting spurs these HSS will give great results with repeat performance as they are made from high alloyed ball bearing steel.
Suitable for all Festool drills including the CXS and TXS 12V and 18V drills. Simply insert it into the CENTROTEC tool chuck and lock it, and you're ready for efficient working.
Supplied in a strong case that will also fit into a Festool compartment case lid.
The CENTROTEC fitting allows for simple and quick bit change in the Festool CENTROTEC chuck that also locks the bit in place and can be easily ejected even with gloves on for speed and efficiency.
Set contains; 3, 4, 5, 6, 8, 10 mm diameters.
Please note no longer supplied with the cosmetic green 'O' ring on the shank.
