Festool
Festool CENTROTEC HSS Twist Drill Bit & Bit Holder
SKU: 931116
£14.58
£12.15 Excl. VAT
  • Complete drill bit & bit holder with CENTROTEC fitting
  • HSS for drilling wood, plastic and non-ferrous metal
  • Supplied with two replacement drill bits, 4 sizes available.
These HSS spiral drills have a CENTROTEC bit holder which is suitable for use in all CENTROTEC quick change chucks or a standard drill chuck. The high-speed steel drill bit is suitable for drilling wood, plastic and non-ferrous metals. Supplied with CENTROTEC holder and 2 drill bits which are easy to interchange with a hex key. Available in 4 sizes; 3mm, 3.5mm, 4mm or 5mm.
Manufacturer Part Number 493421
Drill Bit Diameter 3.0 mm
Web Attribute Set Festool Centrotec
EAN Barcode 4014549050132
