Festool
Festool Circular Saw Blade Set 3, Wood 168mm x 20mm x 1.8mm kerf
SKU: 113043
£113.98
£94.98 Excl. VAT
  • Includes three blades for fine and universal wood cutting
  • High-quality carbide teeth for long-lasting performance
  • Easy resharpening for consistent cutting quality
  • Festool's colour-coding for quick and easy blade selection
  • Ideal for equipping multiple saws or stocking your workshop
The Festool Circular Saw Blade (Set of 3) is an essential set for your woodworking projects, providing you with the necessary blades for fine and universal cutting. This value pack is perfect for equipping multiple saws or keeping your workshop well-stocked. The high-quality carbide teeth ensure durability and consistent cutting performance, and they can be easily resharpened. Festool's colour-coding system allows for quick identification and selection of the right blade, making your sawing tasks more efficient and enjoyable.
This pack contains 3 blades:
2 x wood fine cut HW circular saw blade: 168mm diameter, 20mm bore, 42 teeth for fine cutting wood, ideal for precise and clean cuts.
1 x wood universal HW circular saw blade: 168mm diameter, 20mm bore, 28 teeth for universal wood cutting, perfect for a variety of woodworking tasks.
Blade Diameter 168 mm
Manufacturer Part Number 578566
Web Attribute Set Circular Saw Blades
EAN Barcode 4014549453087
