Festool
Festool Circular Saw Blade Set 3, Wood & Plastics  216mm x 2.3mm Kerf
SKU: 113044
£212.98
£177.48 Excl. VAT
  • Essential set for frequent sawing applications
  • High-quality carbide teeth for long service life
  • Quick access with Festool's colour-coding
  • Suitable for wood, aluminium, and plastic
  • Saves time and money compared to individual purchases
The Festool Circular Saw Blade (Set of 3) is an essential addition to your toolkit, perfect for your most frequent sawing applications. This value pack is ideal for stocking or equipping multiple saws, comprising the most commonly used circular saw blades for wood, aluminium, and plastic. The high-quality and robust carbide teeth ensure a long service life with consistent cutting quality, and they can be resharpened easily. Festool's colour-coding allows for quick access to the right blade, making your sawing tasks even more enjoyable.
This pack contains 3 blades; 216mm diameter and 30mm bore for mitre saws, kerf 2.3mm.
Wood fine cut HW circular saw blade: 216mm diameter, 30mm bore, 60 teeth for fine cutting wood, ideal for cross and angle cuts.
Universal wood and soft plastic cutting HW circular saw blade: 216mm diameter, 30mm bore, 36 teeth for universal wood and soft plastic cutting, perfect for precise cross cuts.
Aluminium and Plastics circular saw blade: 216mm diameter, 30mm bore, 64 teeth for trimming aluminium profiles and all types of hard and fibre-reinforced plastics.
Blade Diameter 216 mm
Manufacturer Part Number 578569
Web Attribute Set Circular Saw Blades
EAN Barcode 4014549453124
