The Festool Delta 200 sanding shoe is designed for large‑area sanding, precise detail work and edge‑close applications with the DTSC 200 cordless delta sander. Its extended tip and generous contact surface allow you to work efficiently into corners, deep recesses and hard‑to‑reach gaps without changing tools, making it ideal for both detailed and wide‑area sanding tasks.
Clean working is supported by optimised airflow between intake and exhaust, delivering effective dust capture right up to the edges of the sanding area. When used with suitable dust extraction, this helps protect your health while keeping the workspace clean and visible.
Designed as part of the Festool system, the sanding shoe works seamlessly with Granat Delta 200 abrasives. The StickFix fastening ensures secure abrasive attachment, quick changes and reliable grip even during intensive use, delivering consistently smooth results throughout the sanding process.
Compatible with the Festool DTSC 200 cordless delta sander size 145mm x 195mm.
