Festool
Festool ETSC 2 150 Edge Protector For Sanding Pad
SKU: 113008
£16.88
£14.07 Excl. VAT
  • Protects both the sanding pad and workpiece
  • Close-to-edge sanding, ideal for detailed work and finishing touches
  • Simple and quick to attach to the sander
  • Durable construction ensures long-lasting performance
  • Reduces wear and tear on sanding pads
  • Achieves smooth and even finishes
  • Fits the Festool ETSC 150mm Sanders
The Festool ETSC 2 150 Edge Protector for Sanding Pad is an essential accessory for any woodworking professional aiming to achieve precise and flawless finishes. This edge protector is designed to prevent damage to both the sanding pad and the workpiece, ensuring that edges and corners are sanded smoothly without any gouging or unevenness. Its robust construction and easy attachment make it a reliable and convenient addition to your sanding toolkit. By using this edge protector, woodworkers can maintain the integrity of their sanding pads and achieve consistent, high-quality results on every project.
The Festool ETSC 2 150 Edge Protector enhances the performance and longevity of their sanding pads. The protector's design allows for close-to-edge sanding, which is particularly useful for detailed work and finishing touches. Additionally, it helps to reduce wear and tear on the sanding pad, extending its lifespan and saving costs in the long run. This makes it an ideal choice for woodworkers who value precision, efficiency, and durability in their tools. Fits the Festool ETSC 150mm Sanders.
Manufacturer Part Number 578093
EAN Barcode 4014549438268
