The FSK cross cutting guide rails work in combination with the Festool TS60 plunge and HK 55, HKC 55 cordless circular saw. The two together form an easily portable and highly accurate cross cut system allowing precision square and mitre cuts. The level of accuracy produced is normally only experienced using a static mitre saw. The Festool system is more convenient especially when working in situations where a large mitre saw in impractical. The rails feature an adjustable stop system that allows for angled cuts from 0 to 60
Festool
Festool FSK Cross Cut Guide Rails for HKC55/HK85 Saw
| Manufacturer Part Number | 769942 |
| Web Attribute Set | Circular Saw Accessories Rail Length: 420 mm |
| EAN Barcode | 4014549221617 |
