Festool Granat abrasive is composed of hardened aluminium oxide and ceramic grits. Festool Granat offers aggressive stock removal to superfine, finish sanding. It is particularly effective on scratch resistant coatings, hard surface paints and high VOC coatings. This high tech abrasive is resistant to clogging and smearing, it lasts longer and results in a smooth even surface finish. Engineered and manufactured to strict FEPA standards, Festool Granat abrasive guarantees a uniform abrasive coating and consistent sanding results. For sanding most modern paint systems, VOC clear coats, plastic materials, mineral materials and acrylics, Festool Granat achieves consistent, high quality results. 225mm diameter, suitable for Festool Planex Drywall Sander.
Festool
Festool Granat Abrasive Discs 225mm
| Abrasive Material | Aluminium Oxide Ceramic |
| Abrasive Type | Granat |
| Abrasive Backing | Paper Hook and loop |
| Manufacturer Part Number | 499636 |
| Pack Quantity | 25 |
| Abrasive Grit | 80 |
| Web Attribute Set | Abrasive Discs |
| EAN Barcode | 4014549043790 |
