Festool
Festool Granat Delta Abrasive 100 x 150mm (Pkt 10)
SKU: 931623
£9.58
£7.98 Excl. VAT
  • Delta shape for easy sanding of rebates access into corners
  • Aluminium oxide and ceramic grit for hard surfaces
  • Use for sanding wood, melamine lacquers, paints, epoxy filler and similar
  • Engineered and manufactured to strict FEPA standards
  • Uniform abrasive distribution for consistent sanding results
Festool Granat abrasives feature a high tech coating, providing maximum resistance to clogging and smearing. These advanced abrasives last longer, reduce rework and ultimately save you money by reducing costs and achieving a consistent, high quality finish. Festool abrasives are engineered and manufactured to strict FEPA standards, guaranteeing uniform abrasive distribution and consistent results. Festool Granat abrasives comprise hardened aluminium oxide and ceramic grits, and are particularly effective on scratch resistant coatings and high VOC coatings. Granat abrasive is suitable for use on wood, paints, lacquers, plastics, mineral materials, acrylic, repair compounds, epoxy filler and similar materials. These delta shaped sheets enable you to sand edges and rebates; the triangular tip offers easy access into corners. Supplied in packs of ten, these are suitable for the Festool DS 400 and DTS 400 sanders.
Abrasive Sheet Size 100 mm x 150 mm
Abrasive Material Aluminium Oxide Ceramic
Abrasive Type Granat
Manufacturer Part Number 577539
Pack Quantity 10
Abrasive Grit 80
Web Attribute Set Abrasive Sheets
EAN Barcode 4014549138519
