Festool
Festool Interface Pad 80 x 133mm for RTS/RTSC400
SKU: 930362
£12.28
£10.23 Excl. VAT
  • Foam interface pad for sanding delicate surfaces, profiles and contours
  • StickFix hook and loop for quick and efficient abrasive changes
  • Enables re-use of partially used abrasives
  • Turbo dust extraction maximises dust removal
  • Sander runs cooler, extending pad and abrasive life
  • For RTS 400 and RTSC 400 sanders
  • Size 80 x 133mm
This foam interface pad forms a cushion between your sander’s base and the abrasive. It aids the sanding and finishing of delicate surfaces, profiles and contoured workpieces. It measures 80 x 133mm with extraction holes to suit the RTS 400 and RTSC 400 sanders. Festool pads feature the StickFix hook and loop design for quick and efficient abrasive changes, and enable re-use of partially used abrasives. Made in Germany.
Manufacturer Part Number 490160
EAN Barcode 4014549118054
