Festool
Festool Jigsaw Splinter Guards PS/PSB 300 (Pkt 20)
SKU: 930357
£15.98
£13.32 Excl. VAT
  • For use with the Festool PS 300, PSB 300 and Carvex jigsaws
  • Solid one-piece, transparent material
  • Zero clearance minimises tearout, saves time and rework
  • Supplied in packs of 20
  • Made in Germany
These solid one-piece, splinter guards are transparent so as not to interfere with sighting the cutline. They fit the Festool PS 300, PSB 300 and Carvex jigsaws. As you make the initial cut, your jigsaw blade makes a slot in the guard exactly matching its kerf. This ensures zero clearance guaranteeing the cleanest cut possible. The splinter guard significantly improves the finished quality of the cut and eliminates time consuming clean up or re-work, even in tricky materials. Replace the splinter guard each time you insert a new blade into your jigsaw. Supplied in packs of 20, made in Germany.
Manufacturer Part Number 490121
Web Attribute Set Jigsaw Accessories
EAN Barcode 4014549117156
