Festool
Festool Li-Ion AIRSTREAM Bluetooth Battery 18V (5.0Ah)
SKU: 104578
£151.98
£126.65 Excl. VAT
  • HighPower cell technology for endurance
  • Bluetooth connection to Festool extractors (with upgrade)
  • Benefit from auto start/stop when using cordless tool
  • Ideal for machines with high power consumption
  • Higher capacities give longer runtimes
  • 3-LED lit remaining charge display
  • Protective rubber frame around battery
Festool Li 5.0Ah HP batteries with High Power cell technology, with greater endurance than a standard 5.0Ah battery to deliver more power than before. Each battery gives long lasting power with their high-current resistant cells and is fitted with a LED battery charge indicator.
These batteries are Bluetooth enabled for use with the Festool WorkApp or connection to a CLEANTEC extractor for automatic startup when the cordless tool is switched on (Bluetooth compatible dust extractor required).
Smart extended: The Festool app, in combination with the Bluetooth® function of the battery pack, enables clever additional functions, such as the detailed display of the charge status and other operating data such as temperature or charge cycles.
Bluetooth lithium-ion (Li-ion) battery pack with Bluetooth / AIRSTREAM function for all Festool 18 V cordless tools
All battery packs are also fully covered by Festool SERVICE
Battery Capacity 5.0 Ah
Battery Voltage 18 V
Batteries Included 1
Battery Type Li-ion
Manufacturer Part Number 202479
Web Attribute Set Batteries
EAN Barcode 4014549284032
